Profile from an Intensity Graph?
Is there a VI to extract a "line profile" from an "Intensity Graph"?
Hopefuly, the profile could be specified using the mouse.
Thanks for any clue...
Alfred A. Manuel, Dep. of Physics, Univ. of Geneva, 24 quai E.Ansermet
CH-1211 Geneva 4, Switzerland. Phone: +41-22-702.6293 or 6397 or 6224,
+41-22-771.1062 (home). Fax: +41-22-321.5606 or +41-22-702.6869
http://sc2a.unige.ch/~manuel/main.htm Alfred.Manuel@physics.unige.ch
(4,410 Views)
What do you mean by a "line profile"--a single set of data (1 dimensional array of points) taken along a line that is parallel to the x or y axis?
(4,337 Views)
Hi m3nth,
I was wondering if you knew how to do what you've said....i.e. create a line plot from an intensity graph that is displayed on the front panel. Here is a link to an example of the intensity graph that I would like to be able to do the line plot with.
thanks
SS
(4,264 Views)
An intensity graph is just a 2D array. Simply slice out a column or row as desired.
The attached example (LabVIEW 7.0)  lets you graph the slice under the cursor on a waveform graph. It should get you some ideas. 🙂
Message Edited by altenbach on 01-09-2006 02:33 PM
(4,261 Views)
hey altenbach,
very cooool....i never new what the property nodes were for!!! Sweet....this program is wild....
thanks again
best
SS
(4,246 Views)
