Profibus GSD-file read
I'm searching for LabVIEW code, with that I can open a Profibus GSD-File, select a part and then this selected part is shown with all ist's configuration variables. Than I can setup this variables and get a array of Bytes to sent them over the Profibus to a slave.
(3,395 Views)
Ted,
I have looked exhaustively for something like you describe and have never found it. My suggestion to you is to use a third party program to copy the slave GSD files in Eprom and then unless the setup changes you don't have to mess with it again. Applicom and Siemens both sell cheap solutions. Applicom also supports LabView but doesn't yet have the Vi's that you describe. Hope this helps if not drop me an email.
Pete
(3,395 Views)
