Product of first N odd numbers
I tried quite a bit to solve this problem and I can't find the solution for the odd ones. It doesn't take my last term. I need some help.
Create a * .vi for calculating the sum of the first N even numbers and the product of first N odd numbers.
Here is what I get. The EVEN sum is good, but cant figure it out how to get the correct odd product.
Message 1 of 20
(5,808 Views)
What is "Numeric" supposed to represent?  A max number?  Number of elements to process?
Message 2 of 20
(5,795 Views)
If you see my photo, numeric is N. For N=5 we will have first 5 numbers. Sum of even is 0+2+4=6, product of odd should be 1*3*5=15. If I have N=7 sum of even 0+2+4+6=12 product should be 1*3*5*7=105.
Message 3 of 20
(5,782 Views)
What is the result if you change '-1' to '+1'?
Message 4 of 20
(5,770 Views)
For N=0 I get 1, for N=4 I get 15, N=5 for N=6 I get 105, N=7 it is also 105. So still wrong.
Message 5 of 20
(5,765 Views)
Message 6 of 20
(5,740 Views)
Message 7 of 20
(5,739 Views)
... the increment should be outside of the loop
Message 8 of 20
(5,736 Views)
I think numeric Q&R by 2 before the for loop is wrong. floor(2/2) = 1 and floor(3/2) = 1, so you will not get different results for numeric = 2 and numeric =3.
Sum%20Product
Message 9 of 20
(5,726 Views)
Accepted by topic author SebiC98
@Martin_Henz wrote:
Slightly simpler, same result 🙂 :
Message 10 of 20
(5,712 Views)
