11-24-2015 06:37 AM
I'm trying to communicate with network streams, but I'm having some troubles.
So I want to set a bool on the host from a CRIO and I also want to set a bool on the CRIO from the host using 2 netwrok streams.
I made a set reset VI, with a bool for set and reset and a bool as output.
But when I run both VI it seems like he gets stuck in Set-reset VI.
I hope someone can help me
11-24-2015 07:16 AM - edited 11-24-2015 07:17 AM
You used a FALSE constant in a loop that is set to Stop When TRUE. Change that constant to a TRUE and the loop will just run once (which I am sure your intent).
Also in that VI, you can replace the Select function with a simple NOT and that case structure can be replaced with just a wire. After a little cleaning up, it becomes quite small...
