Producer/Consumer vs Master/Slave
In comparing the Producer/Consumer design pattern template to the Master/Slave, it appers to me the only difference between the two is one uses Notifiers and the other uses a Q.
What are the pros and cons of this difference?  Under what conditions would you choose one over the other?
Bill F
(6,929 Views)
Queues can buffer data while notifiers cannot is one difference.
(6,923 Views)
To add to Analog Kid's answer,an extract from defination of producer consumer pattern
The Producer/Consumer design pattern is based on the Master/Slave pattern, and is geared towards enhanced data sharing between multiple loops running at different rates.As with the standard Master/Slave design pattern, the Producer/Consumer pattern is used to decouple processes that produce and consume data at different rates. The Producer/Consumer pattern’s parallel loops are broken down into two categories; those that produce data, and those that consume the data produced. Data queues (which are covered more in-depth in the Queued Message Handler section) are used to communicate data between loops in the Producer/Consumer design pattern. These queues offer the advantage of data buffering between producer and consumer loops.
Regards
Dev
(6,914 Views)
