Producer Consumer Refnum Error
Hi all
I have a Producer/Consumer structer in my Program. On the Frontpanel there are a couple of elements. When I change the state of one of this elements I deliver the refnum of this element to the consumer loop.  With the variant to data i can recive the corrsponding refnum.
My Problem is :
This will just work with one kind of the frontpanel elemnts but not with the others. ( See the attached VI)
I hope someone can help me.
regards
(2,734 Views)
I was able to get it to work by inserting the "To Variant" function in the producer events.  So rather than wiring the cluster into the cluster and depending on the cast there, use the actual "To Variant" finction.
(2,732 Views)
Hi evan
Thank you for the answer.
At this moment I found this solution at:
http://wiki.lavag.org/index.php/Image:Typecasttoanotherclass.png
regards
(2,728 Views)
