Processing data in labview
Hi everyone. I was wondering, if I can measure 2 signals, compare them in a labview and see if the are synchronized or not, and then basically write to a csv file yes or no (for synchronized or not). For example, If I am measuring motor current and frequency generated, I want to see if the rise time of these 2 signals is synchronized? I don't have a VI because  its just an idea and I have no idea how to implement it if its possible. Thanks a lot
Message 1 of 16
(3,128 Views)
LabVIEW has all the tools for that ( measure signals, doing math and signal processing and writing to a text file, etc.).
The main problem is probably defining what "synchronized" means and what kind of differences are acceptable to pass and this is completely independent of any programming language. Once you come to a consensus for that, the implementation in LabVIEW will be peanuts.
Message 2 of 16
(3,090 Views)
Have you figured out the signal acquisition part?
Santhosh
Soliton Technologies
Message 3 of 16
(3,066 Views)
yes, its not a problem since I did that before . But how to process these data in a LabVIEW and get only pass or fail I didn't get. I can record it also in a csv and then compare suing python but its also not the goal here.
Message 4 of 16
(3,019 Views)
Hi Lily,
How would you "compare in python"?
You just need to implement the same algorithm in LabVIEW…
Message 5 of 16
(3,012 Views)
With synchronized I mean they start and stop at the same time, and difference of 10% for example is acceptable. Here, for example, signals are synchronized, so after some data processing I should get True in my ideal world. Thanks
Message 6 of 16
(3,010 Views)
i would check if the rise time of second signal -+10% of the rise time of the first signal. How I can do this is Labview? so far, i mostly did data acquisition in labview and data processing in python
Message 7 of 16
(2,996 Views)
Hi Lily,
somehow your last message vanished…
There's a SignalProcessing functions palette, with a WfmMeasurements subpalette.
Lots of functions to measure pulse parameters!
Start with TransitionMeasurements…
Message 8 of 16
(3,003 Views)
Is it possible to compare sin wave and square wave in this way?  I want to see if they start at the same time or not
Message 9 of 16
(2,987 Views)
Hi Lily,
Yes.
(Please don't spread your questions for the same topic over several threads!)
Message 10 of 16
(2,971 Views)
