Problems with timestamp in DAQmx Acquisition
I'm doing a generate and acquisition with DAQmx 6251 and labview 8.2.
When I generate the signal everything works fine but my acquisiton comes with a system time.
And when I put in charts the problem appears. (Please see the picture)
I want that acquisition (second chart) show me the time like the first chart (generation).  Starts with 0 and finish the 0.1999.
For that I've tried put a property node "XScale.Maximum and Minimum"
nothing!
And also tried use the "Get waveform components" and force to use the same timestamp.
Help?
(2,605 Views)
I'm ok
thanks for help
(2,588 Views)
