Problems with the internal clock
I need to read samples with approximately constante time difference.
I found the example ContAcq-IntClk.c and changed it a little bit and it seems that it work.
But when I use a DAQmx_Val_FiniteSamps with a given count of reads than the last two values will be read to the same time!
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps ,4));
DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Acquired_Into_Buffer,1,0,EveryNCallback,NULL));
DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
E.g. the third and fourth value are read to the same time when I print also the current time in the callback function.
Is this a bug?
Best Regards
Pellaeon
(2,421 Views)
@mod: please delete this thread, it's in the wrong board.
I don't know why my post is in this board, i had opend two tabs in my browser and posted in another board ?!?
(2,416 Views)
