Problems with receiving PChar variable from DLL
I have DLL with function inside:
function CCD_GetSerialNum (ID : Integer; Var sernum :PChar) : boolean; stdcall;
To use this one in LabVIEW I've created CLFN with function prototype:
int32_t CCD_GetSerialNum(int32_t *ID, PStr sernum); (calling convention - stdcall)
I wired input parameters: 0 for ID and empty string for sernum, but function doesn't work... It returns some big value instead of 1 (1 is equivalent to True as I understood), and sernum is empty.
Any suggestions?
PS function works properly in Delphi programm.
(3,709 Views)
I suspect you're having the same problem as the one discussed here.
(3,692 Views)
Hello, I have the same problem, and the other topic doesn't help me at all, do you have the solution to your problem?
Fabrice
(3,487 Views)
Out of curiosity, if your function returns a false, is it represented as a 0?
(3,474 Views)
