Problems with hex conversion
Hello community,
I am using a infrared thermometer which is connected through the serial control. To change the emissivity I have to send a special command, e.g. emissivity 0,95 needs the command (HEX) 84 03 B6. 0h84 is the command and 0h03B6 is the emmissivity 0,95 * 1000 in hex.
When I use a string control which is set show hex everything works fine.
Now I want to programmatically change the emissivity. For that I have to join the command 0h84 and the new value.
The problem is, that I get a string which contains the right hex values, but I have to convert this string into hex string - I mean the same values as if I set a strin control to show hex.
Does anyone have an idea?
Thanks a lot and best regards.
Michael
(3,201 Views)
Hi Michael,
It sounds like you just need to cast the binary data to a string to send it.  We can do this with the flatten to string function.  Please find an example attached, is this what you were after?
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(3,192 Views)
Hi Michael,
James Mc
(3,191 Views)
here we go
Kudo wellcome 😉
EDIT: not fast enough... 🙂
Greetings from Germany
Henrik
LV since v3.1
(3,190 Views)
