cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Problems with function Waveform Generation.vi
There is nothing wrong with the function. It will create a .1 hz signal accurately that can be used by a DAQ board. Change the number of samples to 10000 to get a complete cycle. You are confusing how long it takes to generate an array with how the hardware will output the signal. The source of the signal is just a numeric array. The hardware will take the sample rate, number of points, etc. and create what you want. Your program is not accurately simulating any actual hardware.
Mensagem 11 de 13
742Exibições
Ok, great thats comprihendible. Thanks.
So I think I have to change the Thread. My Problem is not the signal simulation, it is the output! And that will be difficult.
Perhaps someone has experience with the old Meilhaus Cards only mentioned a fiew times in this bulletin board. I use a ME-300.
When i'm right, the DAQ board nearly automaticaly can use the wave (DBL) format of the simulator.
I am at the point that I can use My DIO and AIO. I made the programm run with the Meilhaus examples. The Problem in my case the outputs shows direktly what is generated by the computer.
When you connect the input of the llb used for the ME-300 with the simulator it changes into the waveform DBL wire, so I thought it could handel this format. The problem is that I can not realy find out how the llb works. Meilhaus hasn't got any LabVIEW Prgrammer in the company. The examples they have were written by an external programmer, so they can not help me at this point.
I attach the Vi once again with the additional parts. I'm not shure if it is possible to run them without the installed Meilhaus CD. So please claim if not.
If someone has experience with this I think realy good working stone age card would be more than great. Perhaps it is nessassary to ad a component which prepares the signal for the llb, I dont know....
Perhaps someone has had compareble problems with other not Ni Hardware and has a hint.
Regards
            Philipp
Mensagem 12 de 13
729Exibições
Sorry of course I ment DLL and not llb. I'm sorry it is quite latePiscadela do Smiley
Dennis, perhaps you can help me. You explained in 2005 in the thread A/D programming how to use the examples to connect the meilhaus card with the computer. I'm not sure if I understood everything in detail especiallaly the part with serial and DAQ Programming.  Perhaps there is the Problem....
Mensagem 13 de 13
719Exibições
