I am having trouble executing Run-Time menu from the sub-vi.
Currently my main vi program, which is the first thing that I open up to acquire data from different sources (i.e. dll’s, scanners etc.) opens up a number of sub-vi’s.
I have created several sub-vi’s, which are opened from the main vi’s customized Run-Time menu that I have created (i.e. dsp file). I am using the open panel.vi to open other sub-vi’s. I don’t have any problems opening any number of sub-vi’s through the main vi’s menu.
I would also like to have the option to open other sub-vi’s from any sub-vi’s menu. I succeeded in exporting the Run-Time m
enu from the main vi to the sub-vi using the property node properties however nothing happens (I hear a beeping sound) when I click on the sub-vi’s menu. I don’t know what I am doing wrong. I would really appreciate it if someone can attach a sample code using Run-Time menus on sub-vi’s imported from the main vi.
Nish
