Problems with data sharing between fpga and Simulink via SIT
Hello Frank,
I am currently trying to track down some hardware so I can test out your scenario.  Would you be able to post your files so that I can test with the same files you are using?  We would need the bitfile, and bitfile source in addition to all of your SIT VIs and your model dll and/or model.  If you cannot attach this for security reasons, can you reproduce this with some simple basic files and attach those?
Angela M
Product Support Engineer
Message 11 of 21
(1,492 Views)
Angela,
I would like to send You the code, but I cannot send on a forum because of confidentiality,
I wil call the suport in the Netherlands so that  they can arrange something
Regards
Frank
Message 12 of 21
(1,485 Views)
Hello Frank,
There is not a limit as you mentioned before, but you do have to make sure that the buffer settings for acquiring from your hardware are sufficient.  There is a configuration option in the SIT connection manager that you may need to adjust.  I am posting images of the connection manager and the button I am talking about.  It is on the hardare I/O tab.  Make sure that the number of signals is at least as many as how many signals you are mapping.  The default number is 50, so if you are acquiring from 100 channels, then this number should be 100 at a minimum.  This change takes place when the driver VI is scripted.
Angela M
Message Edited by Angela M on 04-02-2008 02:13 PM
Message 13 of 21
(1,464 Views)
Angela,
 I changed the values in the driver vi itself, and it did not help.
Does it make any difference if  I adjust these values in the SIT manager like you mentioned or adjust them in the driver vi like I did.
Did you already received my code from the support in the Netherlands?
Regards
Frank
Message 14 of 21
(1,454 Views)
Hello Frank,
I did get the code, but have not had a chance to look through it thoroughly yet.
Changing these values in the driver VI should be fine as long as you do not rescript the driver VI, at which point your manually changed values will be overwritten.
Angela M
Message 15 of 21
(1,449 Views)
Hello Frank,
Earlier I had asked you to check the values coming from the FPGA in the driver VI.  I am posting a few screenshots to make sure that we are on the same page.  If the values that I am pointing to are off, then you need to evaluate your bitfile and make sure it is behaving exactly as it is supposed to.
driverVIvalues.jpg shows the node where you should probe your values (this should not be broken wires for you).  Indicatormappedindices.jpg and mappedindices.jpg are two other locations were we can verify this data for your problematic values.
Can you please double check and specify whether these values are nonsense, correct or zero?
Angela M
Message Edited by Angela M on 04-03-2008 08:02 AM
Message 16 of 21
(1,429 Views)
Angela,
did you also recieved the simplified code.
If I run the complete code ( the one I send you first) .
The values are
44 correct
45  ?  hard to tel because they are changing
46  correct
48  correct
61 (IMEP)  ?
 51 (test simulink -4000) = -.122074
If I click on one of the indicators of the inports out and move my mouse over it the values are changing.?????
With the new simplified code I send you, it is more clear to check the values because all indicators on the FPGA  are connected the  Chassis/mod3/AI1.( exept for 51 (test simulink -4000)
Then I can easy check if the values are OK
result
44 same -> OK
45 same -> OK
46 same -> OK
48 same -> OK
51 -1.22074  (-1.22074*1638bit/V = 2000.06 <> -4000) NOK
57  0 -> NOK
58  0 -> NOK
60 0 -> NOK
61  NOK ( not the same as 44,45,46,48)
( you can call my on my mobile )
regards,
Frank
Message 17 of 21
(1,400 Views)
Angela,
the FXP only take effect when the old connection (fromer I16) are removed and reconnected in the SIT manager Hardware I/O
It will now work thanks you and your colleague.
Regards
Frank
Message 18 of 21
(1,385 Views)
Angela,
I was to fast with my conclusions the fxp option does not work, or it works sometimes.
I even removed all dirver vi and generated the driver vi's complete new, and still there are FXP indicators with conversion.
I now give up and wil fix the conversion in simulink.
Message 19 of 21
(1,379 Views)
Angela,
 finally I under stand what to do
1. replace the master bit fiel with the new bitfile in the NI program directory
2. Open the SIT manager
3. rebuild the driver
4. check the conversion in the driver
5. OK, no conversion for FXP
6. the values in Simulink are now as expected
I have a onther question: why are some values gray?
regards
Frank
Message 20 of 21
(1,375 Views)
