Problems with data receive in TCP/IP
You can certainly do that.  But I'm sure you can send the data as bytes and not just as ASCII strings.
If you attached your C code, someone may help.  (though this is a LabVIEW forum and not a C forum.)
In Basic, if you want to print a non-printable character, you'd print out something like chr$(10) which is the new line/linefeed character.  I'm sure C has some equivalent function.
Message 11 of 14
(1,299 Views)
I am searching for the solution in ARM related forums. The ethernet library which I used, is utilizing a high level function for data sending. There must be some low-level functions to send bytes instead of string. I can not shift or replace ASCII characters, becuase I need the complete 0 to 255 values to send numeric data.
Thanks.
Message 12 of 14
(1,288 Views)
Thanks.
It's hard to believe the library would require you to send ASCII.  That would make it almost totally useless.  How would you use this library to download a zip file, for instance?  Remember also that you would have to have a decoder on the other side to decode the ASCII back into a binary string.  In other words, a version of this library would have to exist on every single thing it is communicating with.
I think you are unnecessarily hung up on the fact that it is sending strings.  Sending a string is just a way to send bytes of data.  Remember, a string can contain non-printable characters, too.
Bill
CLD
(Mid-Level minion.)
Message 13 of 14
(1,275 Views)
Let me attach some piece of code:
Spoiler
// buffer is an array of uint8_t
// In library prototype, the data is sent like this:
sprintf(str,"%s\n\r\n\r",buffer);
plen=fill_tcp_data_p(buf,0,(const unsigned char *)(str));
make_tcp_ack_from_any(buf); // send ack for http get
make_tcp_ack_with_data(buf,plen); // send data
These are the definition of functions:
Spoiler
unsigned int fill_tcp_data_p(unsigned char *buf,unsigned int pos, const unsigned char *progmem_s)
char c;
// fill in tcp data at position pos
// with no options the data starts after the checksum + 2 more bytes (urgent ptr)
while ((c = pgm_read_byte(progmem_s++)))
buf[TCP_CHECKSUM_L_P+3+pos]=c;
pos++;
return(pos);
As I understood, when we fill buffer like this:
buffer[5]={48,64,112,0,65};
It is converted into a string like this:
str=0 @ p \0 A
I think the \0 between the array of characters, make the function terminate the string and send: 0 @ p. (Three bytes instead of 5 bytes)
Message 14 of 14
(1,267 Views)
