Problems with builded app and shared variables
I got connection error message (Invalid server: cannot connect to server) when selecting a shared variable using dashboard. The app is running on a Win7 PC.
I have no problem connecting the PC's IP at my dashboard indicator, even, I can select the shared vars library of my app.
I opened the ports on Windows and Router TCP: 2343, 59000-60000 UDP: 2343, 6000-6010, and created new inbound rules for the kads.exe, lktsrv.exe and tagsrv.exe programs and installed the Run-Time 2013 engine on that PC. By the way, the application also has HTML files created with the web publishing tools that is working OK.
When I test the application on my develop PC (with LabVIEW 2013) everything works fine.
Did I miss something?
Msc. Jesus Hidalgo
CLA, and NI Certified Professional Instructor
Discipline, pasion for excelence...
(2,954 Views)
Hello jesushidalgo,
Make sure that there is not a personal firewall enabled on either computer that could be blocking the NI-PSP packets.
Acess https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6vdSAC&l=en-US and see the solution.
Acess: https://www.ni.com/en/support/security/configuring-software-and-hardware-firewalls-to-support-nation... to see how configure software and hardware Firewalls to support National Instruments Products.
Tell me if worked, ok?
Best Regards
Rita Souza
Engenharia de Aplicações
National Instruments Brazil
(2,883 Views)
