Problems with applications
Hi!
I have a problem with application builder.
The software I use works with the computer i made it with, but with other computers it doesn't acquire data. I use NI-6008 and the device itself works with all computers.
The version i made the application with is Labview 8.2.1. Other computers have at least nidaq-mx 8.5 + runtime engine.
The application runs on the other computers, but when I try to write the input-signals value to a chart, the legend starts to flash and nothing happens on the chart, it only asks (before measuring) the directory where to write the measurements like it should.
(2,818 Views)
Did you use global virtual channels in NIMAX? If so then you will need to move then over to the new computer. You could also try moving your actual code to a different computer and see if you get an error. I have a feeling that you are missing a file or channels set up somewhere.
Tim
GHSP
(2,798 Views)
