Problems with a numeric slide control.
Hello Everyone,
First off thank you in advance for your help.  Below is a description of my problem.
I am trying to use a numeric slide control to adjust my z-scale on an intensity graph.  I am using several images to create one high dynamic range (HDR) image and having a slide for my z-scale to adjust it on the fly is much easier to use then manually punching in the numbers.  My problem is that I am covering about 7 or 8 orders of magnitude from min to max in my z-scale.  So in order to see all of the data that is contained in the HDR image I need the slide to cover the full range of min to max value of the image.
When I set the slide scale mapping to logarithmic so I can get more seperation in the values and see and scale through the low end easier, the scale is auto truncated to onle 3 orders of magnitude.  This doesn't work for me, is there a way to fix this?
Example:
When I set the scale on the slide to be the min and max of the z-scale on the intensity graph.  I get values of the z-scale being 2.47E+7 for the max, and 0 for the min.  The max value on the slide scale = 2.47E+7 and the min value = 2.47E+4.  I need the min value to be 0.
Thank you again,
~Daniel DeWitte
(3,390 Views)
Accepted by topic author Tera-Engineer
Daniel,
Log(0) = ?  Exercise left for student.
Try setting the Z Scale.Minimum property to some small positive value like 0.1 or 0.001.
I created a slider and a numeric control.  The slider minimum is set to zero. The numeric control is an integer ranging from 0 to 20. The slider maximum is 10^(numeric). The slider is wired to the Intensity graph ZScale.Maximum property node.
Works fine.
Of course I would put the changes in an event structure rather than writing to the property nodes on every iteration of the loop.
Lynn
(3,382 Views)
Lynn,
Thank you for your help, that was exactly the problem.  The only adjustment that I made is that I hard wired the Z-scale min on the slide control to be .001 as well.  I was more worried about displaying the data then looking at the raw equation of what I was asking the computer to resolve, log(0) is undefined, kind of bad for me when I have a bachelor's  in physics.  It was just one of those things that wasn't even considered.
Thanks again,
~Dan
(3,373 Views)
It is easy to get so focused on the details of a program that you forget to think about what it is doing.  I won't tell your professors.  All you need to worry about is whether they read the Forum.
Lynn
(3,366 Views)
