Problems with Windows 95
I need help
I've created an application that use the serial port to take some
bytes. I used labview 6.0i and run ok in windows 98. I need install
this application in another pc with Windows 95. I have installed the
update to Run Time 6.0.2 and can open the application, but don't work
ok. I don't get the comunication.
What can I do to get it?
Thank you
(2,750 Views)
If you're using VISA for communication, you have to install VISA run-time. If you're using the old serial, the file serpdrv needs to be installed. Also, if you've only installed 6.0.2 run-time, you should update the development system to 6.0.2, save the application to that version, and rebuild it if creating an exe.
(2,750 Views)
