Problems with Multiple TCP/IP Connection
Hi All,
I have an application where i am using three cFP controllers for specific purposes. I am using TCP/IP communication for transfering data.In my host PC i deveoped a Multiple TCP/IP connection manager similiar to NI STM toolkit.
But when any one ( or two) of the cFP powerd off ( or network breakage) happens , the TCP/IP communication with other controllers are getting affected. Also it is taking almost 30 seconds to find out the network failure.
Kindly provide some solution for this problem
Regards
Blackperl
Coding is a combination of intelligent and creative work - someone
(2,982 Views)
Hi blackperl,
how do you handle the connections to the other controllers. Normally there shouldn´t be any dependences. May be the creation of an own instance of a vit for each connections, could be a solution for you.
Hope it helps.
Mike
(2,944 Views)
