Problems with CAMAC and LabView 6.0
I have a Lecroy 2249SG adc with a DSP6001 control board. I upgraded from LabView 5.0 to LabView 6.0 and now my Sub vi's for communicating with the CAMAC do not work. The drivers were from DSP and were for Windows NT and a previous lab member modified them to work with Windows 98. I'm new to LabView and would appreciate any insights you may have. Thanks
(2,802 Views)
What form are the drivers in? DLL calls? CINs? other? Also in what way do they not work? Is the original (unmodified) version of the drivers available somewhere? What were the modifications?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,802 Views)
The drivers are .dll files. When I send a LAM to the CAMAC, I get a Q=0 and/or a X=0 back from the CAMAC - Q=0 means no response, and X=0 means command not accepted. My previous lab member explained the modifications like this: "I remember that I somehow looked at the code and besides a lot of unintelligable symbols I saw things that looked like the expected CAMAC commands except that they had a lot of really strange extra symbols attached to them. I then went into LabVIEW and replaced the expected command names by these slightly messed-up versions and - surprisingly - it worked."
The company who supplied the drivers in the past no longer sells the control board, but I am trying to contact them for original drivers.
I'm attaching the dr
iver(WINCAM32.dll) and the vi that is used to generate the calls.
Thanks.
Shaun
(2,802 Views)
