Problems with Application Builder and Custom Menu
I'm having a problem with my custom menu in my application.  I have a project in Labview 8.2 that has a main VI with a custom menu.  There are three items in the menu:  File, View, and Help.  The File menu contains application items, the View menu contains all user items, and the Help menu contains an application and a user item.  When I build the .exe file and run it, I do not see the "View" menu.  The File and Help menu do show up and appear how they should be configured in my menu file.  I do not understand why only the "View" menu doesn't show up.  The menu on the EXE does reflect all the changes that I made for my custom menu file, except for the View menu, so it seems that the .exe file is partially using the menu file.  Any thoughts?
(2,588 Views)
Check your run time menu. Each item contains an Item Name and an Item Tag. It will show in the list if it has a name. It will not show at run time if the tag is blank. Also check that there is a checkmark in the Enabled box.
If all else fails, delete the VIEW item and recreate it.
     Rob
(2,581 Views)
