Problems whit a LLB for snmp
Dear,
I've seen a couple off old toppics about this LLB.  LLB i use
See the attachement, mine OID dont get translated the rightway.
The problem is that mine OID has a number of 30 bits, 852179988, RRS04v30.  That is split in two, a b11 and then the rest of the number.
But how to solve it i don't know. If someoneelse has a better LLB for SNMP communication of knows a solution for mine problem,
Thank you
(3,033 Views)
It's not appropriate to post a bmp file renamed as jpg to get around the ban. Do you think renaming a file will actually change the format?
(3,024 Views)
Sorry therefor
It was a printsceen in XP, now is it a real JPG
(3,012 Views)
Accepted by topic author Nosw
Already solved it, the fix is put the input of SNMP Encode SubID.vi in SNMP Build OID.vi on U64.
Then even this OID got the rightway translated:
.1.3.6.1.4.1.7829.1.852177940.322961408.1.1.3.0
Hope it's help for someone elseSmiley Wink
(2,990 Views)
