Problems using event structure to write new parameter values to VISA
Dear Bass,
please find attached my labView code for an OMEGA FMA2600 massflowcontroller. As of now I have not implemented queues but Im planing to do so in the future. As of now, the Main.vi example works just fine when using the implemented TypeDef.. Thank you so much for your help in the matter.
All the best,
Jan
P.S.: Unfortunatly my Zip file containing the VI is not excepted by the server. I consequently use the UI Control Suite: Metalic Theme. It seems that this causes larger file sizes. I can however send the LV-Project via PM if you want.
Message 11 of 14
(935 Views)
Hallo,
I uploaded my Files to dropbox. They may be found here:
https://www.dropbox.com/s/31yntbj2xybn1l0/FMA2600_Massflow.zip?dl=0
Files are for LV2014
All the best,
Jan
Message 12 of 14
(907 Views)
Hi there,
here are the Files for LabView 2012.
Sorry for the late answer.
https://www.dropbox.com/s/1mbrgtimkvlemr8/FMA2600_Massflow_LV2012.zip?dl=0
All the best,
Jan
Message 13 of 14
(872 Views)
Hi there,
I just updated the LV2012 upload of the FMA.2600a (see dropbox-link directly above [Message 13]) project to my latest version. I did some minor changes in the serial communication handling, thus ensuring that the values are always comming through at stable speed and confidence.
Any suggestions are very much appreciated.
all the best,
Jan
Message 14 of 14
(843 Views)
