Problems using acquire waveform...
We are trying to read an accelerometer signal using AI Acquire Waveform(it didn't work with similar boxes either).
The problem is that we set a scan rate of say: 10k samples/s and number of samples of 10k.
So every second the buffer is refreshed(so we can see the graph) and there is a big distortion.
Distortion is always the lenght of the buffer. We could do a "blind" acquisition setting a big buffer(# of samples). That would solve the problem but it shouldn't be like that.
Erick
(2,617 Views)
Could you explain a little more what the distortion you see looks like?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,617 Views)
