The best thing to do here it to test each part separately, a terminal
programme like Docklight ( http://www.docklight.de ) will certainly
help you in your investigations.
1. Make sure that you use a null modem cable between the 2 PC's
2 --- 3
3 --- 2
5 --- 5
2. Use on PC1 the Labview program which will send something, start the
terminal program on PC2 in order to test the communication which is
going out from the PC1. (With the terminal program try several speeds,
parity options, ... in order to see what happens and in order to
confirm your communication settings on PC1)
3. Start the terminal program on PC1 and the other Labview Program on
PC2, on PC1 you can simulate the behaviour from PC1 from step 2, and
see the answer from PC2.
4
. When you are sure that both parts are now working fine, the first
Labview Program on PC1 and the second Labview Program on PC2, you can
connect them together. In order to see the communication which passed
through the RS232 line, you can use a third PC with two serial ports
in order to monitor the communication between the two PC's. Docklight
will also be able to do this.
