Problems using LabVIEW 8.6 Web Services
hi,
I just started playing around with 8.6 new feature which is the web service. What I made is a html form which calls my deployed web service and it saves the form parameters into a database. The vi I made is just a simple which uses the "Read Form Data.vi" to read the parameters from the form and it gives back a response using the "Write Response.vi". I
include a screenshot of my web service vi.
1) Firstly I named the "Service name" as ManualEntry. However, when the web service is deployed, and I run the form and submit it, it tries to respond with a link using manual_entry. For e.g if the page I am browsing is http://localhost/ManualEntry/html/Entry.html, when I press submit on the form, the Write Response.vi response will be http://localhost/manual_entry/post.
2) How can I build the web service into a stand alone without needing to launch LabVIEW? Right now, I can only call the webservice only if LabVIEW is launched.
Rando
Message 1 of 1
(3,545 Views)
