I am attempting to run a number of VIs on remote machines from one machine (the front panel machine), using Open Application Reference and Open VI Reference, then telling it to run the referenced VI. This seems to work for VIs on three machines that are running LabVIEW 6.1 (as is the front panel computer), but when I attempt to run a VI in this way on a machine using 6i, it doesn't start running. I'm loading the VI first using Telnet, which works, but the VI just doesn't run when it is told to.
Any thoughts? In the end we may upgrade the 6i machine to 6.1, but being able to run a VI remotely on a 6i machine would be useful until then.
