Problems resetting an array
Altenbach,
I tried to encompass your solution into my problem but was unable to satisfy my conditions. I have an array of these booleans that are used as on off reset states rather than on and off. I am still not sure how to reset the initial #s. If I run the button through the cycle of on, off, reset, then do it again the initial #s stay the same when they should be different. I attached a simple vi to show my troubles.
Thank you in advanced for your help. Also thank you for anyone else's help on this problem either.
~I did not open a new thread because I feel like the solution to my problem can be built off this thread's solution. (please correct me if I am wrong)
Thank you again.
CLD Certified 2014
Message 11 of 13
(748 Views)
By appending to an existing thread, you are robbing yourself of the opportunity to mark the best answer as solution. Especially if a thread is already solved, you should typicall start a new thread.
In any case, I don't quite understand your program. Why are you growing the 2D array without bounds, thus thrashing the memory more and more, the longer the VI runs. Shouldn't there be an in-place solution?
When you reset, you seem to try to replace relevant columns with an empty array, basically leaving the existing column untouched. This does not overwrite anything.
Message 12 of 13
(739 Views)
I will make a new thread. Sorry Jeppe Mortensen for intruding on your thread. Thank you.
CLD Certified 2014
Message 13 of 13
(727 Views)
