Problems importing shared library. IOBluetooth mac framework to Labview
I am trying to import a framework from mac, specifically the IOBluetooth.framework. This library has the wrapper already made from Object-C to C. This library is integrated in MAC OS.
And I am receiving this message:
"The Import Shared Library tool cannot get exported function names from the input shared library file. Please check the input shared library file whether it contains functions. If you want to create VIs only based on the functions in the input header files, please go back to the Select File Page and check the Shared library file is not on the local machine checkbox."
I do not know what I can do.
Thank for your help,
(3,052 Views)
I get the same error often when trying to import DLLs in labview. Its a bit of a lucky packet whether it will work with a DLL or not. Can't find help on the web for this very debilitating error. Im sorry to see no-one has helped you either.
(2,746 Views)
