Problems getting Labview Mobile Module to work..
I have written an labview program (attached) which reads in comma separated serial data, parses it, and displays a couple of charts as long as the data is okay. This uses the VISA driver to read from the serial port. In fact, it's a virtual com port (VCP) that I'm using, with the FTDI driver, and a usb cable, connected to a little microcontroller.
This works great using Labview 2010, but my ultimate aim is to get the program running on a Windows Mobile 6.1 device (Juniper Systems Archer Field PC, based on the Intel/ARM PXA270 processor) and here I'm running into problems.
The first is that I can't even get it to run properly in the emulator (that's what the attached code is for). Perhaps this is to do with the VCP driver. I get some error about needed to install 'virtual pc 2007' (odd). Also the drop down list to select the serial port does not even appear when I run the program in the emulator.
Help! I'm okay with labview but this new world of mobile devices is turning out to be more painful than I expected...
Dave
(3,380 Views)
please! I'm desperate... can anyone help with this? anyone?
(3,335 Views)
Hi Dave,
Can you give me a little more detail about the error message you are getting. What is the full message? Is there an error code in addition to this?
I have tried running the code with highlight execution and noticed it was always switching to the timeout case. Do you also experience this?
Kind Regards
Michael
NIUK Application Engineer
(3,321 Views)
