Problems by using MEASURE BUFFERED POSITION
I�m using the VI MEASURE BUFFERED POSITION for reading a sequence of position of a rotary encoder with a PCI-6602.
If I rotate the encoder so that channel A leads channel B, I get the right results with X1, X2 and X4 encoding. If I change the rotating direction, so that channel B leads, the counter doesn�t decrement how it is described in the user manual.
In my application the counter increments, but not with the right number of steps, which should come from the encoder.
I'm waiting for your answers as soon as possible.
Floh
(2,511 Views)
Hello Floh,
I didn't understand 100% the problem. If this example doesn't help you, please give some detail informations.
Which PCI Card do you use?
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E55356A4E034080020E74861&p_node=DZ52130&p_source=External
TN
(2,511 Views)
