Problems With Shift Register
Hi..
How do i reinitialize values after shift register has been used to sort the data. From the attached file, in figure 1, the block diagram is used to separate negative value and positive value. Using shift register, the 'sorting' step will repeat itself...as seen in figure 2 where the array were filled up again & again with the same value...
I've tried to create this sorting system without shift register ...but it will not work....shown in figure 3 & 4
Appreciate anyone who can help me with this..
Message 1 of 11
(6,272 Views)
You need to ... initialize the shift register. This means you need to wire an empty array of DBLs to the left node of the shift register as so:
When not initialized, the shift register will continue to hold its values while the VI remains in memory. This is documented in the LabVIEW Help.
Tip: OpenG has a VI that can do this for you.
Message Edited by smercurio_fc on 06-03-2010 12:09 PM
Message 2 of 11
(6,254 Views)
Please post your actual VI or a screenshot as a .png file.  Don't embed an image in a proprietary MS Word file format.  A bitmap in a Word document took nearly 1/2 MB, while the VI or a .png screenshot would have been perhaps 50 KB.
Right click on the left hand shift register and select create constant.  It will create an empty array constant.
This is basic LabVIEW knowledge.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 3 of 11
(6,252 Views)
First of all, please do not post a Word document.  Post your vi itself.  We can't troubleshoot a document, but we can troubleshoot code.
You need to create an empty array and wire it to the left shift register before the loop.  This way, when the vi starts, the shift register will be empty.
WOW, I lost the race.  Smercurio and Ravens Fan, don't y'all have work to do? Smiley Very Happy
Message Edited by tbob on 06-03-2010 10:10 AM
- tbob
Inventor of the WORM Global
Message 4 of 11
(6,250 Views)
As with many of these basic questions, the answer lies in the shipping examples. Look at the one called 'Separate Array Values'.
p.s. And please, in the future, do not attach word documents.  LabVIEW is programming language and the code is required to do any real dubugging.
Message 5 of 11
(6,239 Views)
Just work that I don't want to do. Smiley Very Happy
Message 6 of 11
(6,235 Views)
Same here.  Thank God for the LV forum.  Smiley Wink
- tbob
Message 7 of 11
(6,230 Views)
Aside from what everyone said about initializing and word documents, which is all true, you can do what you're trying in a single loop.
Tim Elsey
Certified LabVIEW Architect
Message 8 of 11
(6,228 Views)
While we are on the subject, why are .doc files even allowed by the filter?  It is just a lame way to circumvent the other file format restrictions (even lamer than zipping).
Message 9 of 11
(6,215 Views)
Yeah, I don't like doing Ravens Fan's work either.
Message 10 of 11
(6,173 Views)
