Problems Running a TCP/IP Data Server VI as a Windows XP service
I need to run a TCP/IP data server as a Windows service.  As my first step, I modified the LabVIEW example "Multiple Connections - Server.vi" under the TCP.llb to eliminate all controls with constants.  I can run succesfully the VI under the LabVIEW environment and get the data from other computers in the network using the "Multiple Connections - Client 1.vi"
After read and followed the instructions posted in the document "Creating a Windows NT Service Using LabVIEW", I was able to create the Windows XP service.  The "task manager" shows it running.  A freeware Etherenet port monitor shows it listening.  When I try running my client, the port monitor shows a connection being established but after few seconds goes into a "time_wait" state and stays there.  End result: the client does not get the data.
Any hints will be highly appreciated!
(2,612 Views)
Hola buen día,
Para darte una mejor solución podrías decirnos  que aplicación estás tratando de hacer?. Que versión de Labview tienes?
Saludos,
NorSa
(Former) NI Applications Engineer Latin America
(2,583 Views)
