Problem with web server using a built application
I've been using Labview for a year or more, and have developed an application that works fine.  It allows for web server viewing only.  When I use this vi using a computer with Labview installed everything is fine, but recently I have tried to build an application but no longer can remote computers connect over the internet.  The built application works fine as far as measurements etc, but it seems I'm missing something regarding the web server portion.  Any ideas will be appreciated.  I'm using Labview 7.1 and Application builder 7.1 on XP computers.
(2,721 Views)
Is the built application's INI file set to enable networking? As an experiment, copy the INI file from your development system to the runtime version and see if it makes a difference.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,710 Views)
