‎02-16-2007 05:19 AM
‎02-16-2007 05:46 AM
The answer is simple - automatic resizing doesn't work perfectly, so don't use it at runtime.
If you want to do moving and resizing of some elements as you change the panel size, you can set only a single object to scale (in the edit menu) and the others will be moved in relation to it.
You can also set all of your texts to the application font and then change it in the application's ini file (e.g. appfont="Arial" 24), but that only takes effect on restart.
‎02-16-2007 05:28 PM
‎02-17-2007 12:16 PM
