Problem with un-initialized shift register datatype
I am trying to create an un-initialized shift register in a while loop.  When created the default type is Void.  If I wire a constant (initialize on the left side) with the data type I want, the shift register arrows change color to the appropriate data type.  However if I then remove the initial value the arrow returns to black and the void data type.  I want it to remain the color and the data type with no input (initialized).  How do I accomplish this
(3,310 Views)
Set the type inside the while loop
(3,305 Views)
Try using the "First Call?" function along with a case statement inside the loop. There are many ways you can do it.  See attachments for a couple simple suggestions.
(3,303 Views)
