07-13-2015 08:04 AM - edited 07-13-2015 08:11 AM
I have an issue with the 3D plots in LabVIEW. I tried to create a 3D Surface and a 3D Scatter plot.
For the 3D Scatter plot I connected 3 1D-Arrays but unfortunately there was no graph shown after the extraction of the data.
Also I am confused what needs to be connected for the z-axis of the 3D Surface plot since it requires a 2D-Array. What do I need to connect to it?
I attached a picture of the current data extraction in the attachments. Essentially the current program is performing a sweep, a frequency sweep with a varying voltage.
The problem is that none of the data which was extracted is reprensented in the 3D graph, the graph is blank.
Thanks and best regards
07-13-2015 08:18 AM
Hi Sunny,
you need to connect a 2D array of the data you want to plot to it. If you look at the graph from the top, you see an x-y- plot if you will. The Z Matrix tells the graph what z value a certain Point (x,y) has. There's an example for it as well, which demonstrates this fairly well.
As for your BD, I suggest getting rid of all the variables (why doe you use "step freq (Hz)" twice right next to each other? Also I would get rid of all the stacked sequences.
