Problem with state machine
Hi everyone,
I am building a measurment system with a state machine. I dont know how but somehow I lost all the cases labels in the case structure.
Can anybody help me with it. There are the numbers, and it supposed to be the names of cases.
Thanks!
(2,990 Views)
Accepted by topic author vladosaurus
Hi vlado,
you need to use the very same enum definition in all places!
- In case 7 there are two different enums wired to the select function (as you can see by the coercion dots)
- in case 10 there is NO enum wired…
Recommendation:
- Instead of using very long control labels (like "Geben Sie die Kapazität ein (Ah):" you should use a somewhat shorter, but descriptive label (like "Capacity"). In the frontpanel you can always hide the label and show the caption instead!
- NEVER hide labels in the blockdiagram!
(2,975 Views)
