Problem with start a communication with FT4232H-56Q
I have module FT4232H-56Q and on begin i try run UART. I use D2XX drivers and function from ftd2xx.dll. The problem is that when I try get "Description" of device by FT_GetDeviceInfoList(), FT_GetDeviceInfoDetail() or FT_ListDevices() LabVIEW just turn off. Before calling the above functions I call a function FT_CreateDeviceInfoList. Once in a while I get error communicate.
I attach .dll, .sli, .gtype files, gvi file with program, D2XX Programmer's Guide and error comunicate.
(4,280 Views)
Since You do not share your code it is very hard to say.
But some tip:
There are two different views of programmers on that kind or errors.
1. Possible reason: Bugs in Labview
You can find tips for solve this issue at:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9TXSA0
2. Possible reason: Bugs in your code:
For example example if error accurs when your program calls  "Call lIbrary function node" the solution is:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8WkSAK
(4,263 Views)
Accepted by topic author RadoslawKlocek
Actually he does share the code but it is for LabVIEW NXG. As I don't have that installed currently I can't look at it. But the symptoms are clear. Bad SLI (Shared Library Interface) configuration. Most likely he is forgetting to prellocate string or array buffers that the DLL wants to write into, assuming that the primary datatypes do match the DLL headers of course.
Rolf Kalbermatter  My Blog
(4,258 Views)
Thanks, rolfk.
I checked the types of function arguments and found the right type by trial and error. Problem solved, thanks!
(4,218 Views)
