Problem with signal acquisitions graph
Hello
I am a new labview user.
I try to acquire a signal from potentiometer(measure the position of DC motor) to DAQ USB 6212
after I run the DAQ Assistant, I only got graph within 1s.
If I just simulate a sinusoidal signal and define the graph's x axis to 10s
I also only get this, what should I do to solve this problem? thx
(2,702 Views)
The Chart looks much better than graph, but the chart has not time axis....
(2,685 Views)
Just defining the axis is not sufficient. You should generate the signal for 10 secs and plot to see the results.Smiley Happy
(2,681 Views)
Hi DTUlab
Seems like you could use a good introduction to LabVIEW and graphing your data. Feel free to give me a call on 45 76 26 00, and I will give you a nice introduction to LabVIEW.
You should be able to configure the time axis on a waveform chart to fit you application needs. I.e. you can have that each sample is 10s or 0,1s on the time axis and you can define what absolut time format you would like to start with, i.e. 11-september-2012 14:56.
Best Regards
Anders Rohde
National Instruments Denmark
(2,669 Views)
