Problem with serial port in LabView 7.0
Hi!
I have installed the LabView 7.0 and now COM port does not work. Before it had installed the LabView 5 and the COM port worked correctly. I have verified the configuration of the port and seems that everything is correct, I have proven with the Loopback.vi and it does not work.
What happens, would have to add something to the installation of the LabView 7.0?
Thanks to all!
German, from Spain.
(2,855 Views)
I had the same problem.
check here: http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0E91?OpenDocument&node=132060_US
and try to download your version of the driver and runtime. this might work.
(2,848 Views)
Ok, Thanks.
It already works correctly, only I needed a VISA driver.
(2,836 Views)
