Problem with runing .exe
i have already add NI_Vision_Acquisition_Software.lvlib into the projekt. But when i runing the .exe it still seems to short of some NI_Vision_Acquisition_Software.lvlib. Can some1 help me? Thank you very much!
Message 1 of 8
(4,586 Views)
does this occur on the same computer you develop the application on or on a different one where you deploy your vision application?
If the latter is the case, make sure you build an installer that includes the Vision Acquisition software, as is explained here: Which Runtimes Do I Need to Deploy My Vision 2009 Application?
Which version of LabVIEW Vision are you using?
Regards
Peter
Peter A.
Field Sales Engineer, NI Germany
Message 2 of 8
(4,552 Views)
hi,
first of all, thanks for answering. This occur on the a different computer where i deploy my vision application. Im using Labview 2010 and hope to run .exe in another computer which have already install the Run-Time engine 2010. Must i build a installer rather than a simple .exe?
Message 3 of 8
(4,544 Views)
Hi, Please ensure that you have required drivers installed on the new machine where you want to run the exe.
Creating an installer would be good idea.
Message 4 of 8
(4,539 Views)
hi, what do you mean by  "required drivers"? Is Run-Time engine 2010 not enough? im a little confusedSmiley Indifferent
Message 5 of 8
(4,532 Views)
"Required Drivers" to run the hardware. Your run-time engine is required to run the software. I'm sure you must have installed MAX with imaq drivers with it. Pl ensure that you are able to run the hardware using MAX.
Message 6 of 8
(4,518 Views)
Hey,
yes, in order to use the driver on the target computer, you need to either
- build an installer including the Vision Acquisition software OR
- install the vision acquisition software on the target computer first
Please note that for every computer that you want to use Vision hardware on, you will need a run-time license.
Let me know if you have further questions.
Peter A.
Message 7 of 8
(4,509 Views)
hello, is that mean i have to install the NI Vision Run-Time Engine and get a license for that? I found the Vision Run-Time Engine at <Vision>\Run-Time Engine\vision2010rte.exe
But the NI Vision Run Time License is really expensiveSmiley Indifferent
Message 8 of 8
(4,495 Views)
