07-25-2011 05:03 AM
I just downloaded three drivers RSZV instrument "Rohde & Schwarz". But these drives - after what I understood, only work with versions of LabVIEW that are shown on the link below. I utulise version 8.6 of LabVIEW.
When I installed the drivers and I want to access the sample correspandants, I can not find it!
even when I go to the back side of labview I find Inquiring points instead of its functions
Solved! Go to Solution.
07-25-2011 05:26 AM
Dear za3im_ensa,
Thank you so much for your post on our webforum. Where did you put the files? I created a folder in the C:\Program Files\National Instruments\LabVIEW 2010\user.lib folder and unzipped the files to this location. After this I reopened Labview and I was able to find everything on the user libraries palette of my functions palette.
I tested this with Labview 2010, where I was able to put some of the functions on my block diagram.
07-25-2011 06:28 AM
yes that's exactly what I did.
So I think I have another problem that prevents me from seeing this feature!you are welcom;
07-26-2011 03:25 AM
Dear za3im_ensa,
with RSZV Data Read Trace.vi you are able to select different data types, is this what you are seeking? If not please give a more extensive description of what you are trying to achieve. Please refer also to the examples from the appication palette from the vector analyser.
