Problem with "Read Delimited Spreadsheet"
Hey everybody,
I am very new to Labview and currently trying to read a CSV file containing 3000 Datapoints measured by an oscilloscope into Labview for some analysis. The format is as follows:
For this, I am using the "Read Delimited Spreadsheet" vi, with two probes to debug my problem:
The Probe 9 shows, that the string is read correctly:
however no matter which format specifier I use for the "Spreadsheet Strong to Array Function", the output at Probe 8 always ends up like this (converted to integer for some reason?):
Since the examples for the Format Specifier Syntax did not feature Input in scientific notation, I am assuming this might be the problem. Is there any way for me to get an ouput in scientific notation using this vi, or do I need to do something more complicated?
Any help is appreciated
Naeryan
(4,613 Views)
Accepted by topic author Naeryan
Hi Naeryan,
which decimal separator is used in your regional computer settings?
Try the format code "%.;%f" to force the point as decimal separator!
Don't forget to use the comma as separator in SpreadsheetStringToArray…
(4,590 Views)
wow, that did actually fix the problem. I just changed the "use localized decimal point" option and now it even works without your format code. Seems like a somewhat counterintuitive thing to have as a default setting.
Thank you for the quick help
Naeryan
(4,582 Views)
