Problem with ok button
hi,
  im using an ok button to generate some events and i change its boolean text dynamically. What happens is the size of the button changes in accordance with the boolean text. How do i have a fixed size for the button and change the boolean text alone.
Jay
(3,167 Views)
You should probably size the button such that even the largest expected boolean text fits comfortably.
(If this does not help, can you show a simplified example that demonstrates the problem?)
(3,163 Views)
well... i dont think its possible... and it also dont make any sense to keep the same button size if your boolean text is oversize.... 😞
(3,154 Views)
