Problem with image multiplication
I am working on an image processing application and I have a problem with multiplacation of image. I use an autothresholding function to get a binary image. After thresholding I want to superimpose binary image with image taken with a traditional camera. The problem is that I need to multiply every pixel value of the binary image by 255 to get proper results of image fusion. To multiply image I used IMAQ multiply function which seems to work properly. After multiplication I need to convert image to array, so I used imagetoarray function. Unfortunately I don't get proper values after this operation - all array values are 0. I appreciate any help with this problem.
I attached the vi with added a comment next to the conversion function.
(3,299 Views)
I'm not sure if this is the problem, as I've only done a little image manipulation.  I believe that, by default (unless you specify otherwise), images are U8 gray-scale quantities.  If you multiply a U8 by 255 (Sgl) and express the result as a U8, the result will be 255 for all values except 0 (when it will be 0).
Does your thresholded image autoBthreshold 4 image look all black (or white -- I can't remember which color = 255)?  If so, then your code is "doing what you told it to do", which might not be the same thing as "doing what you want it to do" ...
(3,270 Views)
It looks like you're right. I made this VI again from basics using only IMAQ functions and now it works fine. Thanks a lot.
(3,249 Views)
