Problem with front panel refresh
Thx for reply.
In attachment my vi with only the code needed for graphic purpose. To raise the problem just open the vi and play a little with the scrollbars.
I have just realized that the problem raises the first time you click on a control on the right side of the front panel. If you click a control on the left side no problems. For repaint the window just minimize and restore it, or resize it.
>The other CAR deals with our panel being offset to an unexpected place (internally, not on screen).  You should recreate your front panel in this case.
I hope this in not the case 😕
Thanks.
Paolo Bozzoli
Message 11 of 13
(1,184 Views)
Good news and bad news.
Bad news:  it looks like the problem that this VI has is the worse of the two.  That is, that the panel is offset internally.
Good news:  I believe I can fix it with out you building your VI again by opening the VI in 8.5 and saving it back to 8.2.  If you have access to 8.5, you can do it, or you can send the VI to me.
If you aren't comfortable posting your entire code, you can send this VI to jeffery.peters_AT_ni.com.  I only need the VI that has the problem, not any sub VIs.
Jeff P
Message 12 of 13
(1,170 Views)
I fixed the problem using the Labview 8.5 trial version.
Message 13 of 13
(1,150 Views)
