Problem with formula waveform in LabVIEW 8.5
Hi
I was wondering if I am the only one with this problem.
I have installed LabVIEW 8.5 yesterday, and I'm not able to use the Formula Waveform.vi like before.
I was on LabVIEW 8.2.1 before and I was able to pass only the amplitude "a" as a variable to the formula input.
Now, in LabVIEW 8.5 I'm not able to do this anymore, the function return the following error: NI_MAPro.lvlib:ma_evalFormula.vi:3<ERR>
Invalid variable names.  Allowed variable names are: w, f, t, fs, a, or n
Is it something that NI removed or forgot?
Is it voluntary?
(3,982 Views)
I can confirm that this is a new 8.5 problem.
If you dig down in the code, you can see that "ma_evalFormula.vi" does some extra song and dance to validate the formula, and it apparently fails for some valid inputs.
(Workaround: A formula of "a*t/t" would give your desired result).
Of course there are probably better ways to generate a "constant" waveform. 😄
Message Edited by altenbach on 09-14-2007 10:11 AM
(3,966 Views)
I know it may not be the best way to create a constant waveform, it's was just easier for me.
I use a case structure to send the formula to the waveform generator and one of my cases is a constant.
Thanks anyway for the confirmation of a bug.
(3,943 Views)
I made a quick report in our monthly bug thread.
Most likely, someone from NI will followup with a comment. 🙂
(3,937 Views)
Ok thanks
(3,931 Views)
This was reported to R&D (# 4DGGKPQU) for further investigation.  Thanks for the feedback!
Noah R.
Regards
Noah R
Applications Engineering
(3,874 Views)
