Problem with float and spreadsheet string to array
When I use that string with your code (taking everything else out) it works for me as below.
Message 11 of 15
(2,129 Views)
Accepted by topic author Naxmouk
@Naxmouk wrote:
I tried %;%f but it did not worked.
You have to try %.;%f. See the dot between % and ; ?
Message 12 of 15
(2,122 Views)
Thank you, now it works !
I had %f instead of %.;%f
Message 13 of 15
(2,112 Views)
It is really weird, I put %.;%f instead of %f and it works now.
Message 14 of 15
(2,109 Views)
Hi Naxmouk,
This is not weird - it just works as expected…
Did you read the LabVIEW help on all those format codes?
Message 15 of 15
(2,072 Views)
